Washer Started Making Noise Now It Keeps Making Noise And Belt Keeps Falling Off
It makes noise when belt falls off.... have you replaced the belt ? it probrobly has lost its tension and needs to be replaced with a factory replacement belt.
Open the door and check if the drum is moving up and down. If it does then the problem is a bad rear drum bearing. The rear drum bearing comes as a part of the rear shell. - The part number for the rear shell is AP2578105 Here are the break down diagrams for the GE washer Model WPXH214A0WWGene.
