carlos p
#1 Posted : Tuesday, March 4, 2008 1:11:34 PM(UTC)
carlos p
Washer Started Making Noise Now It Keeps Making Noise And Belt Keeps Falling Off
charrie
#2 Posted : Tuesday, March 4, 2008 1:33:56 PM(UTC)
charrie
It makes noise when belt falls off.... have you replaced the belt ? it probrobly has lost its tension and needs to be replaced with a factory replacement belt.
#3 Posted : Wednesday, March 5, 2008 10:04:32 AM(UTC)
Open the door and check if the drum is moving up and down. If it does then the problem is a bad rear drum bearing.
The rear drum bearing comes as a part of the rear shell.
- The part number for the rear shell is AP2578105
Here are the break down diagrams for the GE washer Model WPXH214A0WW
dryer belt keeps falling off (Dryer Repair)
by saltima 12/3/2008 7:27:48 AM(UTC)
