dan523
#1 Posted : Tuesday, March 4, 2008 9:42:10 AM(UTC)
dan523
Makes squeekey noises from front bottom. Comes and goes. Sometimes really loud sometimes very quiet. Took off front and top but still have a hard time reaching back side of motor where belt and pulley's meet. Are there grease fitting to grease on motor or pulley or can I reach in with WD-40 and spray pulley? Is belt dressing okay to use? Also, can bottom come off without pulling out drum or motor? Any help is greatly appreciated.
#2 Posted : Wednesday, March 5, 2008 9:26:26 AM(UTC)
Hi Dan,
You can easy access the idler pulley by removing the rear cover panel.
Here are the break down diagrams for the GE dryer Model DSXR453EV1WW
glen65
#3 Posted : Wednesday, April 2, 2008 7:25:45 PM(UTC)
glen65
Hello.
There are no grease fittings on the motor. I dont recomend spraying
WD40 on any of those moving parts, and do not use belt
dressing. From the description you gave a the belt
and idler pulley are your most likely culprits and should
be replaced.
Guest (4)
Noisy Dryer (Dryer Repair)
by family guy 8/24/2013 3:12:08 PM(UTC)
Loud noisy dryer through whole cycle but works (Dryer Repair)
by joannesnauta 3/8/2012 10:04:17 AM(UTC)
noisy dryer when running sqeaky and vibrates (Dryer Repair)
by Dale Powers 5/11/2011 12:41:42 PM(UTC)
Noisy dryer (Dryer Repair)
by pncope29@gmail.com 10/11/2010 4:49:25 PM(UTC)
by juneschild 8/17/2010 10:34:51 AM(UTC)
noisy dryer (Dryer Repair)
by lramsey00 1/20/2009 3:43:19 PM(UTC)
by ge1209 11/13/2008 1:42:22 AM(UTC)
by marti73 10/28/2008 9:27:57 AM(UTC)
by tmta4irish 7/24/2008 4:17:52 PM(UTC)
by Davyd 5/27/2008 5:06:55 PM(UTC)
by james steward 3/17/2008 9:16:56 AM(UTC)
Noisy Dryer - Sounds like we are polishing rocks when it is running (Dryer Repair)
by this old house 1/26/2008 5:43:40 AM(UTC)
noisy dryer when on (Dryer Repair)
by ellashoe 10/21/2007 8:58:02 PM(UTC)
