FJ Pierce
#1 Posted : Monday, March 3, 2008 7:57:09 AM(UTC)
FJ Pierce
The countdown timer on my Bosch dishwasher stops at 1 minute and continues to run. Opening door shows soapy water in bottom of washer. Closing door resets the timer to 13 minutes which then counts down to 1 and then continues to run. Will replacing the control module (shu 53/68) fix the problem? Any Suggestions?
FJ Pierce
bambiblaster
#2 Posted : Tuesday, March 4, 2008 6:20:01 PM(UTC)
bambiblaster
That has been the most common culprit on Bosch when the unit hangs up...
#3 Posted : Wednesday, March 5, 2008 12:14:19 PM(UTC)
As bambiblaster said, it has been one of most common problem caused by a bad control module. Replacing the control module should fix it.
- The part number for the control module is AP2802870
Here are the break down diagrams for the Bosch dishwasher Model SHU5306 UC/06 (FD 7705-7912)
