Is there a fuse on the actual unit somewhere that I can replace? Tried changing the element out and something popped and the oven shut down, tried the reseting the breaker but the oven still won't come on, I was hoping there is a fuse some where on the oven itself I can change out? Thanks for your help
Check the hi-limit switch for continuity (#18 on the oven break down diagram). Replace if it's open. - The part number for the hi-limit switch is AP379049 Here are the break down diagrams for the Jenn Air range Model FCE2012BGene.
