tconroy
#1 Posted : Monday, March 3, 2008 5:16:46 AM(UTC)
tconroy
Is there a fuse on the actual unit somewhere that I can replace?
Tried changing the element out and something popped and the oven shut down, tried the reseting the breaker but the oven still won't come on, I was hoping there is a fuse some where on the oven itself I can change out?
Thanks for your help
#2 Posted : Monday, March 3, 2008 7:48:26 PM(UTC)
Check the hi-limit switch for continuity (#18 on the oven break down diagram). Replace if it's open.
- The part number for the hi-limit switch is AP379049
Here are the break down diagrams for the Jenn Air range Model FCE2012B
