dcwike
#1 Posted : Tuesday, November 24, 2009 12:42:54 PM(UTC)
dcwike
All of a sudden the dryer will not heat. Did as suggested - tripped the breakers - nothing.
How do you check the "vent?" (That was the next suggestion) Can't get the back cover of the dryer off.
Someone said it may be that we need a new thermostat, too. How do you replace them?
Any help is greatly appreciated.
#2 Posted : Wednesday, November 25, 2009 5:31:17 AM(UTC)
Take it apart and clean/check it. Once done and the dryer is running, start it and then check that the outside vent opens fully.
Here is a good site with troubleshooting and dis-assembly help. Note your unit is basically a GE.
http://www.applianceaid.com/dryers.html
Just undo the wires to it and replace it.
Sounds like your thermal fuse may be blown.
Best and safest way to check most components is with the unit unplugged using a meter.
dcwike
#3 Posted : Wednesday, November 25, 2009 6:40:32 AM(UTC)
dcwike
Thank you very much, denman. :) Will try all that.
