AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer won't heat and I don't know how to take the back cover of the dryer off to chec
All of a sudden the dryer will not heat. Did as suggested - tripped the breakers - nothing.
How do you check the "vent?" (That was the next suggestion) Can't get the back cover of the dryer off.
Someone said it may be that we need a new thermostat, too. How do you replace them?
Any help is greatly appreciated.
How do you check the "vent?" (That was the next suggestion) Take it apart and clean/check it. Once done and the dryer is running, start it and then check that the outside vent opens fully. Can't get the back cover of the dryer off. Here is a good site with troubleshooting and dis-assembly help. Note your unit is basically a GE. http://www.applianceaid.com/dryers.htmlSomeone said it may be that we need a new thermostat, too. How do you replace them? Just undo the wires to it and replace it. Sounds like your thermal fuse may be blown. Best and safest way to check most components is with the unit unplugged using a meter. |
THIS FORUM IS DEAD!!!!!!! |
Thank you very much, denman. :) Will try all that.
Dryer Repair
