brandiannh
#1 Posted : Tuesday, November 24, 2009 9:35:02 AM(UTC)
brandiannh
I have a washer that just started to smell of burnt rubber and it did not drain. I took off the front to see it it was the belt again and that is fine. I ran it and the water comes in but does not drain all the way. Everything underneath was spinning and sounding ok.
sidfink43
#2 Posted : Friday, November 27, 2009 9:41:02 AM(UTC)
sidfink43
I would check the pump and drain hoses. If you need more info please post a model number and any more description you think would be helpful.
