diamondr
#1 Posted : Sunday, November 22, 2009 5:12:49 AM(UTC)
diamondr
I have a maytag dryer model LDE8506ACE it does't heat and timer does't move but timer will move in cool down cycle. What do i need to check and who?
#2 Posted : Monday, November 23, 2009 5:48:51 AM(UTC)
Replacement parts for MAYTAG LDE8506ACE | AppliancePartsPros.com
Here is a manual. It does not specifically show your unit but I beleive it is close to a LDE8414
http://www.servicematters.com/m...ibrary/docs/16008714.pdf
Does the timer advance in timed dry.
If yes, the problem could be just a blown heater or cycling thermostat.
In auto modes the timer motor only gets power when the thermostat opens.
So if the heater is shot it will never open and you will have no heat and no timer advance.
Unplug the unit and inspect the heater.
Or unplug the unit and measure the heater with a meter. Should be around 10 ohms.
another no heat dryer question (Dryer Repair)
by davidlswenson 12/30/2014 9:43:21 AM(UTC)
Confusing troubleshooting on no heat dryer (Dryer Repair)
by bmpmsnow 5/18/2011 8:30:34 AM(UTC)
No Heat Dryer Problem (Dryer Repair)
by SpeedyG 10/28/2008 5:02:39 PM(UTC)
My no heat dryer puzzle for you wizards. (Dryer Repair)
by jfull1965 10/22/2008 2:28:54 PM(UTC)
No Heat dryer (Dryer Repair)
by chaionsaw 12/21/2007 9:59:15 AM(UTC)
