chaionsaw
#1 Posted : 17 years ago
chaionsaw
I have no heat . I want to chexk the fuse but I cant seem to get the bottom cover off. It seems like it is springed to some thing. No clicking noise at all like the heat is not even starting..
#2 Posted : 17 years ago
The first thing I would check is the thermal fuse (#59 on the bulkhead parts break down diagram).
In order to remove the bottom panel you have to push in (using a putty knife) the retainer (#46 on the cabinet break down diagram) on each side on top of the bottom panel.
Replace the thermal fuse if it's open.
According to the manufacturer instructions, if the thermal fuse is open, the cycling thermostat has to be replaced either (#42 on the bulkhead parts break down diagram).
If there is nothing wrong with the thermal fuse, then check the igniter (#4 on the burner break down diagram).
- The part number for the thermal fuse is AP3133489
- The part number for the cycling thermostat is AP3131939
- The part number for the igniter AP3094138
Good luck.
chaionsaw
#3 Posted : 17 years ago
chaionsaw
Thank You that is what it was fuse.. thank you very much and have a great christmas...
#4 Posted : 17 years ago
I'm glad you were able to fix it.
Merry Christmas and Happy New year!
another no heat dryer question (Dryer Repair)
by davidlswenson 10 years ago
Confusing troubleshooting on no heat dryer (Dryer Repair)
by bmpmsnow 14 years ago
NO heat DRYER (Dryer Repair)
by diamondr 15 years ago
No Heat Dryer Problem (Dryer Repair)
by SpeedyG 16 years ago
My no heat dryer puzzle for you wizards. (Dryer Repair)
by jfull1965 16 years ago
