pmiller678
#1 Posted : Wednesday, February 27, 2008 2:11:57 PM(UTC)
pmiller678
my washer has stopped draining it sounds like the pump is working but it did this 2 weeks ago left it over night and the next day it worked again ..???? what could it be :confused:
#2 Posted : Thursday, February 28, 2008 11:52:06 AM(UTC)
If you can hear the drain pump running but it's not draining - most likely there is a foreign object stuck in the pump and/or drain hoses.
Remove the bottom panel, remove the hoses from the pump and check everything. If the pump impeller is damaged - replace the drain pump.
- The part number for the drain pump is AP2108084
