my washer has stopped draining it sounds like the pump is working but it did this 2 weeks ago left it over night and the next day it worked again ..???? what could it be :confused:
If you can hear the drain pump running but it's not draining - most likely there is a foreign object stuck in the pump and/or drain hoses. Remove the bottom panel, remove the hoses from the pump and check everything. If the pump impeller is damaged - replace the drain pump. - The part number for the drain pump is AP2108084 Gene.
