bram
#1 Posted : Tuesday, November 17, 2009 7:06:57 AM(UTC)
bram
I have a kitchenaid convection oven model: KEBS247DWH9 with the inner pane of glass broken. I have the repair part but the door will not remove per the manual or other info found on the web. Any tips? I am trying to avoid the $120+ service fee. Thanks for any info.
#2 Posted : Tuesday, November 17, 2009 8:06:46 AM(UTC)
bram
#3 Posted : Tuesday, November 17, 2009 8:32:17 AM(UTC)
bram
Thanks! I will give it a shot. Do you think Allen wrenches will work for the door removal pins? The oven is 9 years old and i do not have the pins. thanks again.
#4 Posted : Tuesday, November 17, 2009 8:51:15 AM(UTC)
Cannot see why not.
bram
#5 Posted : Tuesday, November 17, 2009 9:13:22 AM(UTC)
bram
inner glass replacing: is this something you would advise against for seals/insulation reasons? and have a professional replace? Thanks again.
#6 Posted : Tuesday, November 17, 2009 1:11:15 PM(UTC)
I do not think it needs a pro.
After all a pro put it in to start with and it still broke.
Just take your time and make sure it is fitted/centered correctly.
bram
#7 Posted : Tuesday, November 17, 2009 2:11:27 PM(UTC)
bram
You have been extremely helpful. Thanks so much. Bram
