I have a kitchenaid convection oven model: KEBS247DWH9 with the inner pane of glass broken. I have the repair part but the door will not remove per the manual or other info found on the web. Any tips? I am trying to avoid the $120+ service fee. Thanks for any info.
THIS FORUM IS DEAD!!!!!!! |
Thanks! I will give it a shot. Do you think Allen wrenches will work for the door removal pins? The oven is 9 years old and i do not have the pins. thanks again.
Do you think Allen wrenches will work for the door removal pins? Cannot see why not. |
inner glass replacing: is this something you would advise against for seals/insulation reasons? and have a professional replace? Thanks again.
I do not think it needs a pro.
After all a pro put it in to start with and it still broke. Just take your time and make sure it is fitted/centered correctly. |
You have been extremely helpful. Thanks so much. Bram
