LUISCARRANZA
#1 Posted : Sunday, November 15, 2009 6:41:46 PM(UTC)
LUISCARRANZA
My Dryer Has Not Power Same Times?
#2 Posted : Monday, November 16, 2009 4:09:05 AM(UTC)
Need more info on the symptoms.
When it does not have power is this after it has been run and then you have to wait a while and it will restart. This could be your motor overheating.
If it is just random, check the breaker pane and the wall receptacle for a loose connection.
Also check in the unit at the terminal strip.
