My Dryer Has Not Power Same Times?
Need more info on the symptoms.
When it does not have power is this after it has been run and then you have to wait a while and it will restart. This could be your motor overheating.
If it is just random, check the breaker pane and the wall receptacle for a loose connection. Also check in the unit at the terminal strip. |
THIS FORUM IS DEAD!!!!!!! |
