dynamite
#1 Posted : 17 years ago
dynamite
I successfully replaced the cam risers on the fresh food door but am puzzled on how to perform that same function on the freezer door due to the embedded ice maker. Electrical wires enter from the top (no problem) but the water line runs through the lower cams (problem). The line can be disconnected but the connector will obviously fit through the cam.
Any ideas?
#2 Posted : 17 years ago
Disconnect the water line and remove the compression nut from the tube to put the tube through the cam.
After it's done, install the compression nut back on the tube and reconnect the water line.
Cam risers for Samsung RSG257aars (Refrigerator & Freezer Repair)
by jericoholics 5 years ago
Removing Freezer door/water line on side-by-side to install new cam riser (Refrigerator & Freezer Repair)
by RSMBob 13 years ago
Door Cam Riser (Refrigerator & Freezer Repair)
by BConley 15 years ago
by FLOWONUSA 15 years ago
Cam riser replacement (Refrigerator & Freezer Repair)
by etshoun 16 years ago
