dynamite
#1 Posted : Monday, February 25, 2008 8:14:22 PM(UTC)
dynamite
I successfully replaced the cam risers on the fresh food door but am puzzled on how to perform that same function on the freezer door due to the embedded ice maker. Electrical wires enter from the top (no problem) but the water line runs through the lower cams (problem). The line can be disconnected but the connector will obviously fit through the cam.
Any ideas?
#2 Posted : Tuesday, February 26, 2008 3:40:22 PM(UTC)
Disconnect the water line and remove the compression nut from the tube to put the tube through the cam.
After it's done, install the compression nut back on the tube and reconnect the water line.
Cam risers for Samsung RSG257aars (Refrigerator & Freezer Repair)
by jericoholics 6/1/2020 3:09:28 AM(UTC)
Removing Freezer door/water line on side-by-side to install new cam riser (Refrigerator & Freezer Repair)
by RSMBob 3/5/2012 8:00:33 AM(UTC)
Door Cam Riser (Refrigerator & Freezer Repair)
by BConley 5/10/2010 9:07:17 AM(UTC)
by FLOWONUSA 10/10/2009 1:29:43 PM(UTC)
Cam riser replacement (Refrigerator & Freezer Repair)
by etshoun 9/27/2008 4:44:22 PM(UTC)
