I have an Electrolux WRS6W1EW0 side by side. The water side dispenses fine but the ice maker overfills with water flowing out onto the floor. It will still make ice, and the bar will rise to shutoff as its supposed too, but it continues to flow into the machine even once its filled. Any advice or part recommendations?? Thanks in advance.... Adam ![UserPostedImage](http://www.********************.com/Schematics/Frigidaire/PN6S71NG.gif)
Hey Adam it sounds like the water fill valve has gone bad. it is located on the backside of the refrigerator and will have a water line connected to it. if your refrigerator has a water filter built into it then it may have 2 seperate valves.
