fan moter runs, compressor does not, frig and refrig is hot, ice melting, what could be the problem? :mad:
I would check to see if it's stuck in defrost. If not then I would check to see if you have power to the compressor start relay.
If you have power to the start relay and the compressor does not run replace the relay.
Probably a bad compressor start device if the compressor is warm, order AP4367355
