the water dosn't shut off and it overflows and gets the floor wet
If it will not shut off when you shut off the machine you will need to replace your inlet valves.
If it does shut off when you shut off the machine it is likely the tube from the tub to the water pressure switch is obstructed or off, or the switch itself is faulty.
If you want more info please post your full model number and the results of checking what is stated above.
