ibejohn
#1 Posted : Thursday, November 12, 2009 8:03:07 PM(UTC)
ibejohn
The timer knob on my dryer is stuck. I noticed it was difficult to turn when trying to make a selection and eventually it just stopped moving on a timed dry setting. I let the dryer cycle finish and the knob popped back up, but now when I press it in it no longer turns.
I took off the control panel housing, but there isn't much to see besides the timer kit/harness and I'm unable to see why it might be binding as it appears to be all internal to the timer. I can pop the knob back out (pushing from the other side), but this does not help it turn.
Is there anything else I can try before I order another timer kit for it, presumably
Part Details - SPEEDQUEEN Kit, timer & harness, part number: AP2403123
I have used the dryer a number of times this week and it has otherwise been operating fine.
Thanks,
John
sidfink43
#2 Posted : Saturday, November 14, 2009 2:17:02 PM(UTC)
sidfink43
Hi John
Unfortunately timers are for the most part non-repairable parts and even more unfortunately yours is a fairly expensive one, but I think you have to replace it to fix your dryer.
Timer knob stuck (Washer Repair)
by segers41 12/9/2012 7:34:54 PM(UTC)
