Mr.
willymack
#1 Posted : Thursday, November 12, 2009 9:04:30 AM(UTC)
willymack
I get no heat. It is either a fuse, thermastat or heating element. How do I determine which one? And where is the fus?
#2 Posted : Thursday, November 12, 2009 2:53:29 PM(UTC)
Here are your parts includes a wiring diagram.
Replacement parts for MAYTAG PYE2300AYW | AppliancePartsPros.com
Could be you are not getting 240 volts. Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without tripping the breaker and the heater needs the full 240 volts.
Better yet measure it with a meter
L1 to L2 should be 240 volts
L1 to Neutral and L2 to Neutral should be 120 volts.
Unplug the unit.
Remove one wire from the heater and measure it. Should be around 10 ohms.
Remove one wire from the hi-limit thermostat and measure it. Should be 0 ohms.
Remove one red wire from the operating thermostat and measure it. Should be 0 ohms.
The thermal fuse in this unit kills power to the machine so would not cause your problem.
mr. harry grupp (Refrigerator & Freezer Repair)
by harry grupp 1/19/2013 4:19:51 PM(UTC)
mr. (Dryer Repair)
by andrewwhirlpool 3/19/2012 8:29:27 PM(UTC)
mr. (Dishwasher Repair)
by charles alfano 8/29/2011 11:25:18 AM(UTC)
Mr. Demetrius Stubberfield (Dryer Repair)
by stubbed 10/24/2010 7:49:33 AM(UTC)
Mr. (Microwave Repair)
by ceffiwill 9/29/2010 9:51:07 AM(UTC)
Mr. (Oven Repair (including Ranges and Cooktops))
by wildbill1942 8/12/2010 3:16:56 PM(UTC)
Mr. (Dryer Repair)
by tomlane261 4/2/2010 12:40:53 PM(UTC)
Mr. Landry Rucker (Oven Repair (including Ranges and Cooktops))
by Landry Rucker 3/24/2010 9:07:42 AM(UTC)
Mr. Mike (Dishwasher Repair)
by goodnurse 1/16/2010 8:54:09 AM(UTC)
mr. don deck (Washer Repair)
by dondeck 9/17/2009 3:55:59 PM(UTC)
Mr. Ng. (Refrigerator & Freezer Repair)
by duantuan 9/3/2009 2:22:56 PM(UTC)
mr. john taylor (Oven Repair (including Ranges and Cooktops))
by taylorjr.john357 8/14/2009 9:28:59 PM(UTC)
Mr. Taylor (Dryer Repair)
by taylorjr.john357 8/11/2009 6:44:38 PM(UTC)
by taylorjr.john357 8/10/2009 1:06:40 PM(UTC)
Mr. C (Oven Repair (including Ranges and Cooktops))
by David Camargo 7/24/2009 3:11:04 PM(UTC)
