iron_mike
#1 Posted : Wednesday, November 11, 2009 7:29:54 PM(UTC)
iron_mike
my dryer started sqeeking and now the drum does not rotate, how do i repair this or what is the repair part get the drum rotating again?
Qtip
#2 Posted : Wednesday, November 11, 2009 8:01:10 PM(UTC)
Qtip
Most likely the rear bearing needs to be replaced. does the back of the drum lay down a little lower than the front? if so then thats a good indication the rear bearing needs to be replaced
iron_mike
#3 Posted : Thursday, November 12, 2009 5:28:05 PM(UTC)
iron_mike
yes it appears this is correct. how do i replace the bearing, and how do i get to the bearing?
iron_mike
#4 Posted : Friday, November 13, 2009 7:02:03 PM(UTC)
iron_mike
how to i get the dryer drum and replace the bearing. i dont know how to replace the bearing.
