my dryer started sqeeking and now the drum does not rotate, how do i repair this or what is the repair part get the drum rotating again?
Most likely the rear bearing needs to be replaced. does the back of the drum lay down a little lower than the front? if so then thats a good indication the rear bearing needs to be replaced
yes it appears this is correct. how do i replace the bearing, and how do i get to the bearing?
how to i get the dryer drum and replace the bearing. i dont know how to replace the bearing.
