2 Pages<12
gary1717
#11 Posted : Wednesday, June 2, 2010 2:48:45 AM(UTC)
gary1717
Hello All,
If you have experienced a dishwasher fire or near fire, please have a look at the following website and add your model and serial number with a description of what happened. Perhaps we can gather enough cases to generate a recall, lawsuit or class action suit against Whirlpool.
The website was created by a home owner Steve Chamber, that this also happened to. KitchenAid Dishwasher Fire | KitchenAidFire.com | Unsafe Consumer Product | Whirlpool Needs Recall |
Please take the 10 mins. to fill in your info, who knows where it could lead. May be it will save just one life and even get us reimbursed for our losses.
I have a Kenmore Elite Dishwasher that nearly burst into flames on May 29th 2010 at 10:00pm. Luckily I discovered the smell and smoke before I went to bed. My model is 665.16279400, purchased in Nov. 2004. Circuit board burnt both knife connectors right off the board and melted a hole in the plastic case that holds the board. It also started to over heat the wiring and melt the casings of the wires.
Gary
gary1717
#12 Posted : Wednesday, June 2, 2010 2:52:51 AM(UTC)
gary1717
Hello All,
I have a Kenmore Elite Dishwasher that nearly burst into flames on May 29th at 10:00pm. Luckily I discovered the smell and smoke before I went to bed. My model is 665.16279400, purchased in Nov. 2004. Circuit board burnt both knife connectors right off the board and melted a hole in the plastic case that holds the board. It also started to over heat the wiring and melt the casings of the wires.
Gary
le54is
#13 Posted : Wednesday, June 2, 2010 9:51:00 AM(UTC)
le54is
want pump water ou
gary1717
#14 Posted : Wednesday, June 2, 2010 10:09:34 AM(UTC)
gary1717
What is it your asking le45is?
kenmore dishwasher 66513043K116 still not draining, after changing drain motor? (Dishwasher Repair)
by thivakaran 12/5/2022 11:47:06 AM(UTC)
Repeating Error 24 on Kenmore Dishwasher (Dishwasher Repair)
by abidh2 12/24/2021 4:45:12 PM(UTC)
Kenmore Dishwasher 665.13733K600 Major Leak Problem (Dishwasher Repair)
by Ken More73 11/10/2021 12:22:29 PM(UTC)
Kenmore Dishwasher - no control lights but washer works (Dishwasher Repair)
by toibn46 10/22/2021 10:08:47 AM(UTC)
Kenmore Dishwasher Keeps Running (Dishwasher Repair)
by VicRattlehead 9/21/2021 1:25:13 PM(UTC)
my Kenmore Dishwasher wont start (Dishwasher Repair)
by Guest 6/14/2021 8:14:07 AM(UTC)
Kenmore dishwasher turning on by itself (Dishwasher Repair)
by Guest 5/24/2021 11:06:12 AM(UTC)
Kenmore Dishwasher drain output has stong sulphur smell (Dishwasher Repair)
by Larbo 1/13/2021 3:35:42 PM(UTC)
Kenmore Dishwasher Heater (Dishwasher Repair)
by mikedbom 11/11/2020 4:21:33 PM(UTC)
Kenmore Dishwasher Smartwash (Dishwasher Repair)
by katzman299 1/4/2020 11:02:06 AM(UTC)
Kenmore dishwasher model 665.15113K211 started high pitch sound between cycles (Dishwasher Repair)
by redeyedog 5/10/2019 8:21:48 AM(UTC)
Kenmore Dishwasher control pannel not working (Dishwasher Repair)
by Douglas Scherer 3/14/2019 6:32:33 PM(UTC)
Kenmore Dishwasher fills then drains (Dishwasher Repair)
by qkantaris 1/5/2019 8:39:01 PM(UTC)
How do you install Part W11048936 for a Kenmore Dishwasher (Dishwasher Repair)
by S Hall 3/23/2018 4:46:54 PM(UTC)
Can't loosen impeller part for kenmore dishwasher (Dishwasher Repair)
by rbhall52 9/5/2017 12:04:52 PM(UTC)
2 Pages<12
