AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Both Freezer and Refrigerator not staying as cold as they should
noticed freezer wasn't staying cold over a period of time.....now it is really struggling and the refrigerator does not seem to be as cold either?
Remove the rear panel in the freezer and check how the evaporator is covered with snow. Post the results.
right now my husband is cleaning the coils, we were told that could be the problem if there is dust build up on them. we were not aware that those needed to be cleaned every once in a while.
Quote:...right now my husband is cleaning the coils... Which coils? Did it help? Gene.
no it did not. I have beads of water in the freezer on the back wall of the freezer. Is this a defrost problem?
Originally Posted by: Gene  Remove the rear panel in the freezer and check how the evaporator is covered with snow. Post the results.
Gene. Did you do it? Gene.
