lmacino
#1 Posted : Monday, November 9, 2009 5:03:24 PM(UTC)
lmacino
My dryer runs, but it does not heat up. I looked through the back access panel to see if the ignitor lights up when I start the dryer. It did not. I replaced the igniter, but it still will not heat. When I start the unit, the igniter lights, I hear a click and then the igniter turns off. What should I check next.
lmacino
#2 Posted : Tuesday, November 10, 2009 5:15:20 PM(UTC)
lmacino
I replaced the coils on the gas valve. When I turn on the dryer the ignitor heats up the gas comes on and the flame goes out after a few seconds. I checked the flame sensor, cycling thermostat, thermal fuse and everything has continuity. Any ideas on what is happening. Any suggestions would be greatly appreciated.
lmacino
#3 Posted : Tuesday, November 10, 2009 6:25:07 PM(UTC)
lmacino
The reason why the burner kept shutting down is because I had the front cover off and there wasn't enough air flow thru the vent. Dryer is working fine with the front panel back in place.
