My dryer runs, but it does not heat up. I looked through the back access panel to see if the ignitor lights up when I start the dryer. It did not. I replaced the igniter, but it still will not heat. When I start the unit, the igniter lights, I hear a click and then the igniter turns off. What should I check next.
I replaced the coils on the gas valve. When I turn on the dryer the ignitor heats up the gas comes on and the flame goes out after a few seconds. I checked the flame sensor, cycling thermostat, thermal fuse and everything has continuity. Any ideas on what is happening. Any suggestions would be greatly appreciated.
The reason why the burner kept shutting down is because I had the front cover off and there wasn't enough air flow thru the vent. Dryer is working fine with the front panel back in place.
