I have just installed a new ice maker (old one did not function at all) and it makes ice but will not cycle on its own. If I flip the lever, the ice is dumped out of the tray, it refills, makes ice and will not cycle again. The new ice maker is a factory part.
Is there a sensor outside of the ice maker that could be faulty?
Thank you
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
Nhred71, using a thermometer, what is the temperature inside of the freezer?
