presta2424
#1 Posted : Sunday, February 11, 2024 6:50:46 AM(UTC)
presta2424
United States
Motor was not draining. Checked the filter and it was clogged. Didn't drain the next cycle either. Ordered a new pump and removed the OR one. There was what looked like a pc of a gasket in the impeller housing. This ended up being the culprit. Motor Ohm'd out fine so I put back together. Good as new. I'll be returning the new pump I bought.
