Joined: 2/11/2024(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Ohio
Motor was not draining. Checked the filter and it was clogged. Didn't drain the next cycle either. Ordered a new pump and removed the OR one. There was what looked like a pc of a gasket in the impeller housing. This ended up being the culprit. Motor Ohm'd out fine so I put back together. Good as new. I'll be returning the new pump I bought.
