Joined: 1/23/2024(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: TN
Our oven bake element burned up. It left welded debris on the bottom of the oven. I had to use a grinder to get it off. How much of a problem is that shiny spot on the bottom of the oven going to be? Should I coat it with something?
Also, the new element has adhesive residue on it from the manufacturers label. Should I just burn that off or do I need to use alcohol or paint thinner to clean it?
