Ropavejero
#1 Posted : Friday, June 23, 2023 4:37:10 PM(UTC)
Ropavejero
United States
Fridge slowly started to get warmer. Found a lot of dirty lint like build up in the condenser and compressor area. After a couple of hours the freezer temperature was still under -18 celsius but the fridge side seem to be stuck at 11 degrees celsius. This is a Maytag RSD22A side by side refrigerator freezer unit.
I did not check the temperature on the freeze before the clean up but it seems like that side was not noticeable affected.
Guest
#2 Posted : Saturday, June 24, 2023 12:10:49 PM(UTC)
Guest
Rank: Guest
United States
Not freezing green light on bottom door is blinking
