Fridge slowly started to get warmer. Found a lot of dirty lint like build up in the condenser and compressor area. After a couple of hours the freezer temperature was still under -18 celsius but the fridge side seem to be stuck at 11 degrees celsius. This is a Maytag RSD22A side by side refrigerator freezer unit. I did not check the temperature on the freeze before the clean up but it seems like that side was not noticeable affected.
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Not freezing green light on bottom door is blinking
