edw00app
#1 Posted : Tuesday, May 23, 2023 2:02:04 PM(UTC)
edw00app
United States
Cannot find drum bearings for Whirlpool Cabrio WTW5800BW0 washer. The commonly available seal/bearing kit for Whirlpools and a bunch more is W1043502. Have howl on spin cycle which is increasing with each wash so sure the tub bearings are at least part of the problem. I am told my wtw5800 has a fatter shaft than later models. The 5800 part explosion diagram doesn't even show bearings on the tub bottom. Was the whole design changed around after my 5800 was manufactured? The only suggestion I have had so far is to replace the gear case and this does not seem to include any tub bearings. Has anyone fixed a wtw5800 spin howl and what parts did you use?
OneScoutPlus
#2 Posted : Tuesday, May 23, 2023 5:54:07 PM(UTC)
OneScoutPlus
United States
If I'm not mistaken, the tub bearings are part of the platform (gearcase) PNW1145372. Depending on the age, and level of corrosion, the tub may, or may not separate easily from the splined shaft. You may also want to consider replacing the hub PN W10528947. Worst case, the inner tub will also need replacement. Hope this helps.
