BruceJRHunt
#1 Posted : Sunday, January 15, 2023 11:31:05 AM(UTC)
BruceJRHunt
Canada
I have a Ge frontload washer, Model# GBVH6260FWW built in 2005 and bought new in 2006. I replaced the pump last year. The cleanout is clean and seems to drain fine.
It will not go into service mode as the delay button randomly works the signal/extra rinse/ prewash buttons. So I can't get any error codes. Most of the buttons must be pressed a couple of times to make them work.
I assume I need a new control board for that following reason.
I've tested the washer in a 18 minute Rinse and spin cycle.
-When you hit start the door locks and begins to fill with water
-About 2 minutes in the dispensor motion will activate
-8 minutes in, the water level is at the door seal, it will begin to drain. Pump works fine then pulses for 3 minutes. Still no spinning yet
-13 minutes everything stops, the door unlocks and the start button is flashing
-You press Start, the door locks, and it will spin right then left for one revolution
-14 minutes in it begins to fill again
-18 minutes in,(Display still show 4 minutes left)
-22 minutes in at it begins draining
-26 minutes in, (display still reads 1 minute left) pump pulses again for 3 minutes and then stops, and the start button is flashing again.
My question is it worth fixing a 20 year old machine (by replacing the control board) or should I buy another one
thank-you for any help
wilsonjiaho
#2 Posted : Monday, January 16, 2023 9:29:59 PM(UTC)
wilsonjiaho
Canada
could it be one of the drain line is partially plug? (assume the pump is overheated)
GE Frontload Washer - Trouble Shooting Help (Washer Repair)
by mahgnibb 3/14/2024 2:37:10 PM(UTC)
GE Frontload Washer Spin (Washer Repair)
by mahgnibb 2/16/2024 6:13:51 AM(UTC)
GE Frontload washer wont start (Washer Repair)
by burlingtony 6/4/2011 12:10:05 PM(UTC)
GE frontload washer will not lock (Washer Repair)
by dshouf 4/30/2011 12:55:25 PM(UTC)
GE frontload washerwil not spin (Washer Repair)
by bailey78 8/17/2010 5:43:07 PM(UTC)
GE frontload washer pauses randomly and will not wash or spin (Washer Repair)
by sew 7/24/2009 5:37:13 AM(UTC)
