kdgeo
#1 Posted : Saturday, July 30, 2022 11:23:23 AM(UTC)
kdgeo
United States
General Electric gas dryer makes a clunking sound once per revolution with and without a load. I have disassembled it and can't find anything obvious.
Later:
When taking off the rear bearing shaft assembly and heat diffuser found the bracket that holds the rear bearing assembly was cracked and almost completely detached.
Edited by user Saturday, July 30, 2022 12:45:21 PM(UTC)  | Reason: found problem
