kdgeo
#1 Posted : 3 years ago
kdgeo
United States
General Electric gas dryer makes a clunking sound once per revolution with and without a load. I have disassembled it and can't find anything obvious.
Later:
When taking off the rear bearing shaft assembly and heat diffuser found the bracket that holds the rear bearing assembly was cracked and almost completely detached.
Edited by user 3 years ago  | Reason: found problem
