hello all
i have an Amana AER6303MFB2 smooth top range- both large burner elements do not work correctly if set to "3" (somewhat low heat) i will get no heat at all -when set to "4" or "4.5" (in between 4 and 5 on the dial) it will randomly go to MAX heat and stay there
from the parts Q&A there seems to be 4 different infinite switch part numbers??? any suggestions greatly welcomed!
many thanks in advance
