r_pnw
#1 Posted : Thursday, June 16, 2022 12:09:07 PM(UTC)
r_pnw
hello all
i have an Amana AER6303MFB2 smooth top range- both large burner elements do not work correctly
if set to "3" (somewhat low heat) i will get no heat at all -when set to "4" or "4.5" (in between 4 and 5 on the dial) it will randomly go to MAX heat and stay there
from the parts Q&A there seems to be 4 different infinite switch part numbers???
any suggestions greatly welcomed!
many thanks in advance
