Guest
#1 Posted : 3 years ago
Guest
Rank: Guest
Groups: Guests
United States
Kitchenaid no water in icemaker unless jumper valve control then fills till jumper removed and ejects after freezing
Assume I do not need anything but the control module part 628135 ? does that sound right
Is there any way to see why the water switch is not closing at the control module?
I assume discrete water switch repair is not possible and entire module even though timing motor is working) needs to be replaced?
