AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Kitchenaid no water in icemaker unless jumper valve control then fills till jumper removed and eject
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Kitchenaid no water in icemaker unless jumper valve control then fills till jumper removed and ejects after freezing
Assume I do not need anything but the control module part 628135 ? does that sound right
Is there any way to see why the water switch is not closing at the control module? ( I assume discrete water switch repair is not possible and entire module even though timing motor is working) needs to be replaced?
