Hi, I may have made repairs out of sequence / needlessly. 1/ D/W was working great. 2/ smelled burning smell coming from D/W - dry electrical type smell. Unit wouldn't run / power would not come on. 3/ Ordered Thermo Fuse from Appliance parts pro. Installed and unit ran but still didn't dry 4/ Replaced Heater element but unit still doesn't dry. 5/ i think i did a reset by pressing the SCRUB - SANI RINSE - DRY BUTTONS in sequence for 4 times. After which all indicator lights on control panel come on and stay on. 6/ i then ran a cycle but still no heating element working. 7/ Hot water line feeds the unit and we have hot water in unit but clearly no heat from the heater element. I opened door and [ut a cooking thermoter on the heater element and it was about same temp as the hot water in unit. 8/ I checked heater elenent for continuity prior to install and it was fine. Any suggestions.... Thanks Louie Edited by user Friday, April 8, 2022 5:17:46 PM(UTC)
| Reason: Not specified
