louie@DFW
#1 Posted : Friday, April 8, 2022 5:15:51 PM(UTC)
louie@DFW
United States
I may have made repairs out of sequence / needlessly.
1/ D/W was working great.
2/ smelled burning smell coming from D/W - dry electrical type smell. Unit wouldn't run / power would not come on.
3/ Ordered Thermo Fuse from Appliance parts pro. Installed and unit ran but still didn't dry
4/ Replaced Heater element but unit still doesn't dry.
5/ i think i did a reset by pressing the SCRUB - SANI RINSE - DRY BUTTONS in sequence for 4 times. After which all indicator lights on control panel come on and stay on.
6/ i then ran a cycle but still no heating element working.
7/ Hot water line feeds the unit and we have hot water in unit but clearly no heat from the heater element. I opened door and [ut a cooking thermoter on the heater element and it was about same temp as the hot water in unit.
8/ I checked heater elenent for continuity prior to install and it was fine.
Any suggestions....
Louie
Edited by user Friday, April 8, 2022 5:17:46 PM(UTC)  | Reason: Not specified
