davesanderson@sbcglobal.net
#1 Posted : Wednesday, March 16, 2022 12:37:47 PM(UTC)
United States
My upper oven will heat up fine but will not keep the temperature. I've replaced control panel and temperature probe. What should I try next?
ThatGuy
#2 Posted : Wednesday, March 16, 2022 6:45:08 PM(UTC)
ThatGuy
Groups: Expert
United States
I've seen gas oven igniters that would light the oven burner once or twice, then fail to re-light it, causing the oven temperature to fall.
Used to see it all the time on gas ovens. I'd replace the igniter and it was good for another 5 to 10 years. If its just sitting there glowing, but not lighting up, its probably the igniter.
https://www.appliancepar...ectric-jgb870sef2ss.html
