My upper oven will heat up fine but will not keep the temperature. I've replaced control panel and temperature probe. What should I try next?
Groups: Expert
I've seen gas oven igniters that would light the oven burner once or twice, then fail to re-light it, causing the oven temperature to fall. Used to see it all the time on gas ovens. I'd replace the igniter and it was good for another 5 to 10 years. If its just sitting there glowing, but not lighting up, its probably the igniter. https://www.appliancepar...ectric-jgb870sef2ss.html
