I have noticed frost forming on the plastic food containers in my freezer and "drops" of ice on the top of the freezer...evaporator fan seems to function ok, drain is clear, thinking maybe the magnetic seal is leaking a bit...This is in South Florida with moderate humidity and 75F outside temps . Any suggestions as to what it may be?
Joined: 2/3/2022(UTC) Posts: 0  Location: Stamford, CT
Check seals and fit of doors.
