DustinF
#1 Posted : Saturday, January 8, 2022 11:41:41 AM(UTC)
DustinF
United States
Howdy All,
I have an ongoing problem with the Samsung WF45K6200AW/A2 Front Loader Washer where it goes to a cycle and after running water and sensing load it drops to a 4C Error.
Water is ON, hoses are NOT kinked or coiled tightly, they are run water in a bucket just perfectly at a good flow pressure.
What I have done so far:
I have cleaned the filter on the Cold and Hot water intake - No Change
I have cleaned the drain/pump filter - No Change
I have replaced the valve assembly for cold water - No Change
What I am seeing;
It will trigger the cold water valve that goes to the "Pre Wash" detergent assembly and the water will run while the motor spins and it senses load. After a few minutes it will error out to " 4C " and then run the drain/
If water is set to HOT, it will still only trigger the cold water valve that goes to the "Pre Wash"
I am not sure what else to do.
